Spoon LSD question
Originally Posted by s2kneub,Aug 14 2008, 01:22 PM
does anybody have any figures pertaining to the max power you can throw at a spoon lsd+housing without it blowing up? also, how does it compare with the puddymod built diff?
As per AJ Racing sight,
The Spoon differential gear box for S2000 is a stock Honda unit that is disassembled then reassembled to tighter tolerances by Spoon technicians. During reassembly, the technician washes and measures every component, ensuring that the transmission is assembled and torqued exactly to spec. In addition, the technician adjusts the gear contact for optimum LSD performance. The result is a smoother, more efficient, better performing unit over stock.
Price: CAD $2,310.00 (USD $2,310.00)
I have seen the price for this from $750 to over $2,300 US I am not sure if you send in your diff for the work or if they have a core exchange.
The Spoon LSD is not part of this deal it over a $1,200 extra plus bearings. The Spoon LSD is a 1.5 type unit.
The setup can be found on AJRacing or INLINE 4. If you need more information on the Spoon setup these guys would be the best to ask
