Sponsored by: CARiD
SRS light
Old Jan 23, 2016 | 06:34 AM
Jaspah's Avatar
Default SRS light
Hi guys,
I installed a aftermarket steering wheel (nsx-R). I put a 2.2ohm resistor on the yellow SRS connector, and reset the srs light with this DIY: http://forums.clubrsx.com/showthread.php?t=308198
The light resets itself, but comes back on again... So there is a problem.
The resistor is properly connected to the yellow srs connector.
Is there something I'm missing here?
Thanks!
Jasper
Old Jan 24, 2016 | 06:24 AM
Jaspah's Avatar
Whoops, I posted this in the wrong forum. My bad.
Can a mod please move my thread? Thanks!
Old Jan 24, 2016 | 11:19 AM
S2kBird's Avatar
I did this same thing with my passenger airbag, I however bought two 1ohm resistors, put them in series and made my own connector so I could return to stock very easily. Measure your resistor and make sure it's close to the resistance you're trying to meet.
Old Jan 25, 2016 | 04:41 AM
Super Nintendo Chalmers's Avatar
Make sure plugged them in the right holes.
Old Jan 27, 2016 | 02:02 PM
Jaspah's Avatar
It's a connector with 2 pins. It's connected the right way....
Old Jan 27, 2016 | 07:28 PM
S2kBird's Avatar
Options:
1. get the SRS code pulled then go from there, it may not have anything to do with drivers airbag.
2. Reconnect the drivers airbag, reset the code as you have been, if it returns, you have other problems, if it doesn't, your resistor is the issue.
Old Jan 28, 2016 | 09:35 AM
Jaspah's Avatar
Will do.
Thank you
Old Jan 30, 2016 | 05:07 AM
Jaspah's Avatar
So I searched a bit further... seems that disconnecting the seatbelts also result in a srs fault.
I removed them because I run takata's 4p.
Another lesson learned
thnx!
Old Jan 30, 2016 | 06:09 PM
S2kBird's Avatar
Way to get it sorted out!!!
zakazak
Mar 31, 2014 04:58 AM
woodburn
Mar 9, 2012 02:28 PM
Lttakas
Oct 16, 2009 12:46 PM
jazzarb
Jul 20, 2004 01:26 AM
louieville
Apr 11, 2004 05:36 AM
