Sponsored by: CARiD
Status Ring seat bolt size PLEASE HELP
Old Mar 16, 2013 | 01:58 PM
mikey3165's Avatar
Default Status Ring seat bolt size PLEASE HELP
So I picked up a status seat from a member on here and never got the bolts that attach the seat to the rails. Can someone PLEASE help me and tell me the bolt size if they know or if they can check on their own seats.
Old Mar 16, 2013 | 02:13 PM
06Estukay's Avatar
Most seats usually use M8 x 1.25 threads. For length, 20mm should do the trick. Go to your local hardware store, pick one up and try it out. I like using socket head cap screws for seats. I also recommend using lockwashers and/or some loctite blue on the threads.
Good luck!
Old Mar 16, 2013 | 02:29 PM
mikey3165's Avatar
I tried those (M8 x 1.25) and tried 20mm and one size shorter in length and they screw in at first and then get tight after a few turns. Im scared to force and stripping the threads. Also, there is M8 coarse and fine threads.
Old Mar 16, 2013 | 11:18 PM
romeo2's Avatar
The 1.25's are course threads - try the 1's. They shouldn't bind with depth - you will cross-thread or strip the threads on one or the other if you force things. Having said that, a quick check in the Manual shows them as 8x1.25's (F) and 10x1.25's (R) so it would appear that they are 'keyed' so as not to be confused. Like wheel nuts there is a tightening sequence specified - RF, LF, RR, LR and the torque is 18 lbf.ft (F) and 22 lbf.ft (R). Good luck.
Old Mar 18, 2013 | 11:52 AM
mikey3165's Avatar
awesome will try that thanks for the help!!
Robocopy
Aug 9, 2015 11:06 AM
qbmurderer13
Feb 21, 2008 06:13 AM
jlstyle82
Jun 17, 2006 07:08 PM
stewies2k
Sep 9, 2005 09:23 AM
Blue_S2
Jun 23, 2005 06:43 PM
