Sponsored by: CARiD
Stock Headers
Old Aug 27, 2009 | 08:24 AM
Hero's Avatar
Originally Posted by DeadZero,Aug 27 2009, 12:15 AM
back in the day when i was in the NA route. Dude don't waste your time...get rid of the stock headers and buy RICKS headers... TRUST ME!!!
Ricks headers are the exact same as the Mugen headers but much much cheaper. I used to have ricks headers...AEM V2 intake...Apexi g-spec single exhaust and i made 218 @ dyno dynamics.
these cars have been around for 9 years. There has been hundreds upon hundreds of posts regarding NA for this car. i've had mine for over 4 years. if you think your gonna spend 500-700 bux porting the stock headers you might as well buy ricks headers for about 600.
but if i was you i'd just keep the car bone stock until i go FI. Theres no real good gains for NA with this car.
TRUST ME!!! i'm not posting this to waste your time..im posting this from my past experience
actually...don't trust him.
you have an ap2...the ricks header is meant for ap1s only, although it will fit an ap2 just fine.
if you had an ap1, i would say follow his advice ( and mine as i have the ricks too ), but it isn't going to be helpful on an ap2.
Old Aug 27, 2009 | 08:27 AM
Hero's Avatar
Originally Posted by Dancer,Aug 26 2009, 10:02 PM
Since I haven't removed the stock S2000 header and taken a look at the inside of each of the runners, I can't tell you what difference porting would make. I'm not doubting what the others have said but if I were doing this project I would probably want to have a look at the stock header before giving up (but they are probably right). I used to have a 3rd generation Maxima and I had to remove the exhaust manifolds to replace some broken studs. I couldn't believe how inefficient those manifolds were - there were all kinds of obstructions and by the time I got them ported and reinstalled I found that it really did make more power. The difference here is that headers are a lot different than exhaust manifolds - it's unlikely there is a lot of "meat" to remove in a gasket port match. There is one thing that might be worth doing to the stock manifold - while I was at it with the Maxima exhaust manifolds I had them ceramic coated. The studies I've read seem to indicate that holding the heat in the header can give you up to 3-5% more power. If I were replacing or reinstalling a header, there is no way I wouldn't have it ceramic coated. Last time I checked the place that did it for me would charge about $150 for a 4 cyl manifold. Good luck.
no need to wrap the stock header, it has a heat sheild. venting your hood would be a much better use of money and time if you are looking to dissipate heat better.
aftermarket headers that can't reuse the stock heatshield should be wrapped, coated, or given a vented hood to breathe.
Old Aug 27, 2009 | 09:35 AM
mister x's Avatar
^Help me out here guys, I understood the purpose of Dancer ceramic coating his header was too keep the temp up for better exhaust velocity. So if you can't use a heat shield and you vent your hood, wouldn't this result in lower header temps?
Old Aug 27, 2009 | 11:51 AM
Hero's Avatar
i don't know about the velocity thing so i'll let someone else answer.
but if you put in a new shiny header without a heatshield, coating, wrapping, or vented hood you will have a lot of heat under the hood. heat soak = bad. it will steal your power. that's why some people go to great things to keep things at an appropriate temp under the hood.
i don't really know if wrapping or coating a header will make give you more power, but i know if you don't do something about the heat under the hood you will lose any power, and more, you gained by the aftermarket piece.
Old Aug 28, 2009 | 09:51 AM
Mr. LEG's Avatar
awesome replies and thanks to everyone for your help.
In my OP I was just throwing around the idea of P&P cause I know someone at a machine shop. It will not cost $600-700
I meant the it would be $600-700 to get a decent header that was new.
After all your help I think that I will wait on the headers and get a exhaust for now. (that should hold me over until I get a job.
I also need to install my audio stuff.
thanks again everyone
Old Aug 28, 2009 | 10:01 AM
slates74's Avatar
Can someone explain porting a header, I've never once heard of the terms porting and header used together. I understand porting an polishing a cylinder of course.
Old Aug 30, 2009 | 10:07 PM
Dancer's Avatar
Porting a header is pretty simple because there isn't much to do. Because of the smooth surfaces on the inside of tubular headers, there isn't any porting or polishing that you need to do and even if the inside of the tubes had rough surfaces you wouldn't be able to do anything it anyway because you can't get your porting tool more than 3 - 4 inches down the hole. The only possible improvement you can make is to take a look at the openings where the header bolts to the cylinder head. Sometimes the welds aren't perfect and if there is too much heat in the wire, some of the welding material can "sag" into the path of the tubular opening (the hole that the exhaust gases pass through). You can get out your die grinder and remove that material so that the hole is perfectly straight and smooth. Also, there may be some weld "spatter" in and around that tube to flange area. Lastly, if you save the old "crushed" exhaust manifold gasket, you'll have a pretty good idea of what the new gasket is going to look like after you torque the studs to spec. You can fit the old gasket to the new header flange and scribe around the hole of the old gasket, and remove a little bit of material. Make absolutely sure that you don't take any material off the tubing wall itself - just the flange. I'm sure you've heard of it before - it's a very old trick called gasket match porting. This is for the severely anal retentive out there (like me) because it might result in a horsepower increase of 1/4 of 1%.
Old Aug 31, 2009 | 07:44 AM
S2Kage's Avatar
I wasn't aware that we had multiple headerS ... hmm maybe thats why when I only put 1 one it didnt make a big difference, ill look into it...
Old Jun 24, 2010 | 01:08 PM
supaninjaface 12's Avatar
i heard that the stock headers are just as good as anyother aftermarket headers seeing that it has a tubular design. you might as well just keep the stock headers and just get 70 mm test pipe and 70 mm exaust or even the megan 3 inch exaust. the 3 inch exaust would relive the flow a bit earlier right after the test pipe...im trying to get the megan 3 inch hehe! and invidia 70 mm test pipe
Old Jun 24, 2010 | 02:30 PM
MikeyCB's Avatar
Seriously? Why would you go for a huge cat-back exhaust after the first half is the restriction? Unless I'm missing something with how a huge cat-back scavenges the gases better or something for increased velocity, The biggest diff you'll see on N/A exhaust is to go with test pipe, and perhaps a carefully selected header and cat-back to match. Then you'll see some slight benefits from choosing all 70mm.
