Stoptech brake lines
has anyone here installed Stop Tech brake lines before? i have a set that's been sitting in the trunk of my car for a long time that i've been itching to install. unfortunately i suck at figuring things out myself so i'm asking anyone in the forum that has them or has installed them for some instructions or a step by step guide, i tried the website but they just had the full brake replacement instructions... so yeah, any help is appreciated
TIA
Shotiable
TIA
Shotiable
I installed stoptech brake line and im really happy with it.
I used it on the race track twice with motul brake fluid and cobalt brake pad, brake feeling is very firm and steady. i hope you gonna be happy with it.
im sorry i cant explain how install it. i didnt install it.
DIY StopTech SS Brake Hose Install:
http://www.eskimo.com/~mikeg/S2000/brake_hoses/
courtesy of mikegarrison.
You'll be draining your fluid so the big deal here is being prepared to bleed the brakes, if you aren't interested in doing this take it to a shop, Brake bleeding must be done right, because if you don't you will die.
As far as installing the lines themselves:
Remove top of fluid resevoir.
Disconnect lines at the caliper and let them drip into a pan, cup rag, whatever.
I think it might be 2 or 3 bolts on each side. Just look at the line, remove it, and reinstall it.
