Sponsored by: CARiD
Swaybar
Old Oct 20, 2009 | 02:27 PM
s2krev's Avatar
Default Swaybar
How good are the tanabe sway bars? I read that tanabe are hollow. Is that bad? Does that ruin anything? What's the difference?
Best of all... thoughts on the tanabe ones
http://www.tanabe-usa.com/stabilizer.asp
Old Oct 20, 2009 | 08:11 PM
Swiftoy's Avatar
Your OEM ones are hollow. Doesn't seem so bad does it?
Swiftoy
Old Oct 21, 2009 | 09:15 AM
MurderS2K's Avatar
good 411
Old Oct 21, 2009 | 10:05 AM
rjones's Avatar
Nothing wrong with a hollow bar. Most of the tensional stiffness comes from the outer part of the bar. A hollow bar will be almost as stiff as a solid bar of the same material and dia. and a lot lighter. I don't know if the Tanabe bar is any good or not.
Old Oct 21, 2009 | 10:15 AM
spook's Avatar
A hollow bar can be just as stiff as a solid bar if it is made correctly. I can't vouch for the Tanabe sway bar, but Tanabe has good products
Old Oct 30, 2009 | 08:22 AM
s2krev's Avatar
Thanks... I just read a lot about hollow bars. Can't they they were all bad. But just a hint of negative stuff.
Old Oct 30, 2009 | 08:25 AM
JakenBake's Avatar
Make sure you get a good sway bar setup to match your suspension. IF you running stock suspension a new sway bar setup might not help you at all or might give you less handling then the stock stuff. Remember Honda fine tuned everything on our S2Ks.
Moddiction
Sep 11, 2016 06:59 PM
S>>capades
Feb 10, 2015 03:30 PM
Xundart
Aug 23, 2013 11:20 AM
KJ1225
Mar 22, 2007 05:13 PM
