Sponsored by: CARiD
T1R 70RT Headerback Exhaust
Old Oct 26, 2010 | 10:10 AM
.MM's Avatar
.MM
Default T1R 70RT Headerback Exhaust
Can i run this exhaust, being that it is a headerback with no cat or resonator, WITHOUT tuning?
will it be safe? will the car adjust?
ive heard rumors of crazy a/f ratios on the J's racing 70RR without tuning of like 15:1
truth?
thanks
matty
Old Oct 26, 2010 | 11:18 AM
RedCelica's Avatar
any other mods?
Old Oct 26, 2010 | 11:24 AM
suzuka-blue-s2k's Avatar
You will be fine. Many people run full 70mm or 75mm exhausts with full bolt ons and dont have any problems. It does make the car run leaner, but I doubt its to the point where you should be concerned.
Old Oct 26, 2010 | 09:40 PM
wisdom's Avatar
I don't think its necessarily a problem, but you get to maximize your gains with a tune though.
Old Nov 3, 2010 | 08:43 PM
.MM's Avatar
.MM
i was told before that taking a bone stock s2k and slapping a J's Racing 70RR on it without a retune will result in A/F ratios or like 15:1
is this false? maybe the ecu takes time to adjust?
i plan to pick up a 70rr or 70rt and didnt want to tune the car right away...
the 70rr and 70rt are catless and have no resonator headerbacks
Old Nov 4, 2010 | 12:04 AM
H22toF20's Avatar
I'd personally never run a car at WOT with that kind of A/F ratio. From what I've read though, you should be fine.
Old Nov 4, 2010 | 11:54 AM
wisdom's Avatar
I think it would help if you knew where in the RPM band the 15:1 A/F ration is, since you don't stay in a certain RPM range in WOT all the time.
Old Nov 4, 2010 | 12:03 PM
daktruckie99's Avatar
I believe the data you are looking for started from the lips of Giles. He had some cars come in the shop for a tune with his EMU and on the preliminary pulls the A/F were scary lean. These were cars with intake, test pipe, and cat-backs.
It's more of a problem with the later AP2s than AP1s though.
Dev, the Laguna AP2 (06 IIRC) from New Jersey had scary high A/F when he made it to Giles, though I don't recall the exact number. See this: http://holyrollerdyno.com/Holyroller_Dyno/...Dave_Surti.html
-Mike
Old Nov 5, 2010 | 05:34 AM
Clemsons2k's Avatar
Shouldn't have as much of a worry with an AP1 like was previously mentioned. They run richer than AP2's, especially the '00-'01 models. But I would still get a tune whenever you can. Mainly for gains reasons, but better safe than sorry.
Old Nov 5, 2010 | 07:12 AM
Rubn1out4GudLuk's Avatar
[QUOTE=daktruckie99,Nov 4 2010, 01:03 PM] I believe the data you are looking for started from the lips of Giles.
eddiehan0709
Apr 4, 2015 12:09 PM
red@9k
Bay Area For Sale
Jan 16, 2009 07:10 AM
Reaper 6A
Jun 26, 2007 11:32 AM
jcmotorsports
Dec 12, 2006 12:07 PM
JayStyles662
Aug 21, 2005 02:05 PM
