T1R Crankshaft Pulley
Originally Posted by Neutered Sputniks,Feb 20 2010, 11:26 AM
No appreciable gain can be contributed to the pulleys
Originally Posted by gospeedgo1,Feb 20 2010, 06:32 PM
interesting in how the vtec dip was smoothed out with the pullies at around 5500RPM in the graphs.
pretty impressive
Originally Posted by gospeedgo1,Feb 20 2010, 12:25 PM
wow... maybe you did not get the ford racing example. yes, the ford racing pulleys are underdriven but they do not have a harmonic dampener and are sold by ford motor company (see site information on bottom of the page). oh noes, why would ford sell something like that when it "destroys" engines.
the S2000 ones sold by TODA, T1R, and Unorthodox are not underdriven, that is correct. as shown with my previous post with the ford racing example, there are plenty of ones that are underdriven (you can look thru the unorthodox website) and find examples if you would like.
i spent hours looking online doing "useful research" on aftermarket pulleys, i could not find an original post of where the "pulleys will destroy your motor" myth/urban legend comes from that has the motor completely torn apart and gone thru (maybe you could post a link, since you are full of useful information) to eliminate other causes. i did find these two links thou.
http://www.atiracing.com/products/dampers/sae.htm
http://www.moparmusclemagazine.com/techart...mper/index.html
"You must have a reliable damper that is capable of properly combating these vibrations and twist. Your stock damper, or stock style damper, is simply a piece of soft steel that has a rubber ring that has been melted in between another steel ring." i see the piece of rubber on the crank pulley, but is that considered sandwiched?
well, on the bright side, your response did give me the idea to submit it to mythbusters. my post is linked below if you would like to follow it and see if it leads anywhere.
http://community.discovery.com/eve/forums?...401#77719494401
Hey everyone. Has anyone had any issues with these. I have had mine on for about 6 months and was cleaning my engine bay today and found that the water pump pulley has a couple hairline fractures in it coming off of the bolt holes. I will put a pic up tomorrow as it is dark here already. I curious to see if T1R has any warranty or would be willing to do a swap for a new one. Glad I kept my stockys...
