Sponsored by: CARiD
Technical or bolt on?
Old Oct 21, 2012 | 04:02 PM
DavidB223's Avatar
Default Technical or bolt on?
Im about to start buying parts for my build, but im wondering if i should start with bolt on Hp gains like exhaust and header, or cold air intake; or if i should go to things like throttle body and injectors and coils.
Whats your play on it? How did you start? If I buy x, what should be y,z, etc???
Thanks!
Old Oct 21, 2012 | 04:08 PM
postman's Avatar
start with bolt ons and a tune.
Old Oct 21, 2012 | 09:55 PM
dc2-2-ap1's Avatar
I would do (in order) intake, exhaust, SOS big bore throttle body and a tune (will require some form of engine management- piggyback, standalone ecu, flashpro if you are 06+, ect. Those two (throttle body and tune) should be done at the same time.) then finish with a header and maybe some okada plasma packs -if you can justify the price for the minimal gain with n/a setups.
Old Oct 22, 2012 | 06:43 AM
S2KIrishman's Avatar
i think you should do more research before you start throwing parts at it...i think youre going to be very dissappointed when you end up dumping thousands of dollars on mods and you only end up with maybe a 15hp gain...just my two cents though
Old Oct 22, 2012 | 11:52 AM
daher2323's Avatar
Agreed. Don't spend money on bolt-ons until you figure out your long term goal. Will save money in the long run instead of buying I/h/e and then deciding to go turbo for example
silver02s2000
Sep 19, 2013 05:24 PM
ap1_tot
Apr 23, 2010 09:03 PM
APEXSEAL
Jun 20, 2005 03:02 PM
biker1
Nov 10, 2003 06:06 PM
