Sponsored by: CARiD
tein with edfc
Old Nov 4, 2008 | 09:05 AM
westmobs2k's Avatar
Default tein with edfc
anyone on here remember how long it took to install them. including motors and wiring everything up. what about without the edfc
thanks
Old Nov 5, 2008 | 02:51 AM
run115's Avatar
I just did mine about 2 weeks ago, tein circuit masters with dual edfc's, took 1 and a half days, but the work is top notch.
Old Nov 5, 2008 | 06:06 AM
S2K 4 ME's Avatar
If your prepared when they arrive, with car on jack stands, wheels off, I dont think it took me more than 2-3 hours tops. Thats just the coilovers, I dont have the edfc.
Old Nov 5, 2008 | 06:08 AM
S2K 4 ME's Avatar
How was the work top notch? What did you do different? Either you have them on right or you dont.
Old Nov 5, 2008 | 09:04 AM
rdv5434391's Avatar
-- i had it done at a shop, as i lowered the car and adjusted camber, along with alignment to do ti all correctly - about 6 hours shop time iuncluding the alignment - teins with edfc
Old Nov 5, 2008 | 09:31 AM
westmobs2k's Avatar
yea my dampening is already set up. i just heard that wiring it all up and removing the panels in the back are a pita
Old Nov 5, 2008 | 09:38 AM
S2K 4 ME's Avatar
Its probably not to bad really, after wiring in an amp I learned all the secrets.
Behind the passenger seat panel theres actually a pass through you could use, then run them up either side, or up the middle. I dont think it would be to bad. Might take an hour or two extra.
Old Nov 5, 2008 | 09:47 AM
run115's Avatar
I mean since there are two motors on each coilover, there was a few cables to pass through and under the dash, so it took a while to do it neatly. I am a bit of a perfectionist, thats all.
Old Nov 5, 2008 | 11:31 AM
wuttheheezy's Avatar
how do you like your dual edfc? i also have the circuit masters but am contremplating whether to spend my money on the dual edfc's or something else..
Old Nov 5, 2008 | 11:49 AM
run115's Avatar
I havent played much with them yet, but i like them since you can adjust exactly to how you like them. On the softest setting they are still a bit too hard for the roads i drive on, but the handling part makes up for it anyway.
bb_00
Jul 25, 2009 08:45 PM
topnotchAp2
Jan 24, 2008 06:09 PM
Diablo99V
Jan 23, 2007 05:21 PM
GT-Spec S2k
South Florida
Aug 27, 2006 09:15 AM
lagunaS2000
Aug 12, 2006 09:55 PM
