Sponsored by: CARiD
Tein S-tech Springs
Old Apr 11, 2013 | 05:59 PM
rondnoir's Avatar
Default Tein S-tech Springs
Hey I was wondering which is the top and bottom for this spring and which is the front and rear?
From what I have read on the forums and internet.
The TOP has MORE gaps and LESS stiff
The BOTTOM has LESS gaps and MORE stiff
The LEFT is the REAR because it is shorter
The RIGHT is the FRONT because it is longer due to engine weight
Thanks!
Old Apr 12, 2013 | 06:53 AM
TheMuffinMan's Avatar
You see those markings on the springs? That dictates whether they are the front or rear. And the text should be able to be read when they're installed.
If I'm not mistaken, the one on the left says 'F-PIA58-OUO GBC' or something to that effect, and while slightly rubbed off, the one on the right looks like it's '?-PIA59-OUO GBC' but should be an R. If you have the other two springs you should be able to compare.
F = Front
R = Rear
Image someone had in a FS section here on S2ki
Old Apr 12, 2013 | 03:06 PM
rondnoir's Avatar
Perfect, I see it now! Thank you so much!!!! Never knew the front letter indicated whether it is front or rear. Thanks once again!
DannyD_303
Sep 7, 2015 06:58 AM
murderedrsx
Oct 9, 2011 06:06 PM
Nick.
May 16, 2011 11:07 PM
bluextc
Apr 7, 2007 04:59 PM
BlownAP
Jun 15, 2006 10:21 AM
