Sponsored by: CARiD
Test Pipe cel fix Orifice ?
Old Sep 19, 2017 | 03:17 PM
Royaltrophy's Avatar
Default Test Pipe cel fix Orifice ?
I just picked up this Test pipe for my ap1 from a local shop,
When in there I was told that id require a CEL fix kit to stop the CEL when removing the cat pipe.
My question is what size orifice should I be using?
Old Sep 19, 2017 | 03:24 PM
Orleansjunky's Avatar
i would use none at first. then big to smallest if needed. imo the kit you have is overly complicated.
Old Sep 19, 2017 | 03:42 PM
thanks for your reply, I am trying to avoid having to go back under the car
This was the only cel fix they had
Old Sep 19, 2017 | 11:17 PM
flanders's Avatar
The smallest one should have the biggest chance to not throw a CEL so that's what I would use.
But I'm pretty sure you wont need one at all though, at least not if you have a pre 2006 car.
Old Sep 22, 2017 | 12:29 PM
gptoyz's Avatar
on any non DBW i.e. 00-05 this is all you need:
https://frsport.com/CEL-Fix---Check-...SABEgIYCfD_BwE
Old Sep 25, 2017 | 04:16 AM
jst2878's Avatar
Will there be any difference in performance with each different orifice? Any greater chances of leaning out?
Old Sep 25, 2017 | 06:05 AM
silverstone_f22's Avatar
The second o2 sensor does not affect performance at all it is just there to verify the cat is doing its job. There is no chance of that sensor affecting fuel ratios.
Old Oct 2, 2017 | 07:07 AM
AngryTurtle's Avatar
This is my understanding. So just choose the smallest orifice to make the CEL least likely.
VtecTo9K
Dec 22, 2015 06:51 PM
ap2_lumpy
Jul 12, 2009 01:43 PM
04ssonbl
Dec 21, 2008 07:04 AM
J_STATUS
May 10, 2008 03:14 PM
