test pipe installed
Originally Posted by 9kred,Mar 17 2010, 12:44 AM
Give it a week or two and youll get a CEL. I have/did the exact same thing and after I got the CEL I spaced out the O2 sensor and it went away. Just heads up but you should gain some top end with that.
If they put something in your exhaust when they test it then you probably wont pass. If all they do is plug in the OBD2 plug under the dash, and you don't have a CEL, you will pass emissions with the test pipe on. I'm in IL, we only get it every 4 years.
berk says 4-5whp from there test pipe im thinking thats true with supporting mods. and yes the cat was there before same length just alot thicker and test pipe weighs 5 pounds vs 13 pounds for stock cat
Originally Posted by Evil///M,Mar 17 2010, 01:07 PM
Thats it? that thing is tiny..what was there before that, a cat? what kind of gains do you get from that thing?
i have the same tp I get a cel while cruising on the highway. I have not installed any extenders/washers yet, but I guess I will. The cel doesn't bother me to much. Except the tp is supposed to be cel free. BS
