Sponsored by: CARiD
test pipe installed
Old Mar 18, 2010 | 08:32 AM
  #21
Gernby's Avatar
Former Sponsor
Originally Posted by kaissi,Mar 18 2010, 05:46 AM
If you also have Invidia 70mm N1 installed, with stock ECU... You'll definitely going to have a lean mixture. That will make the car much slower.
He will not run lean with just a TP and exhaust on an '02. He could add an intake too, and still need to lean it out for more power.
Old Mar 18, 2010 | 09:01 AM
  #22
Monkeyboi's Avatar
I had to reset my ecu after installing the test pipe on MY00. Felt like the car was going to die on idle. After the reset, it ran just fine. I miss my Invidia N1 + TP.
Old Mar 18, 2010 | 11:28 AM
  #23
05APdeuce's Avatar
[QUOTE=kaissi,Mar 18 2010, 03:46 AM] If you also have Invidia 70mm N1 installed, with stock ECU... You'll definitely going to have a lean mixture.
Old Mar 18, 2010 | 12:47 PM
  #24
kaissi's Avatar
Invidia N1 is too large for NA setup with stock ECU...
from my experience F20C2 AP1 2004...I had UEGO installed.
When I had only AEM V2 CAI and testpipe, the car was making on UEGO AFR at around 13.5 - 14 from 6000-8000 RPM..then around 12 from 8000-9000
when I installed invidia N1.. the AFR jumped to 15..
70mm exhaust is usually used for cars close to 300 HP and not 240HP.
hence.. no backpressure...
Old Mar 18, 2010 | 12:59 PM
  #25
05APdeuce's Avatar
I have never heard of the ap1 guys having issues with leaning out because the car comes from the factory running pretty rich.
Old Mar 18, 2010 | 01:01 PM
  #26
Gernby's Avatar
Former Sponsor
I don't have an opinion about whether the Invidia N1 is too large for an NA setup or not. That all depends on the harmonics.
However, I've had lots of experience with my previous S2000 ('02) with an LM-1 Wideband and a custom piggy-back ECU. The lean spike that you see at VTEC isn't really a problem. My '08 AP2 when it was nearly stock AND my brother's totally stock '06 AP2 both have a lean spike up past 14.5:1 at the VTEC transition.
Old Mar 18, 2010 | 01:23 PM
  #27
s2k dre's Avatar
Lean=more power.
Old Mar 18, 2010 | 01:35 PM
  #28
Gernby's Avatar
Former Sponsor
Originally Posted by s2k dre,Mar 18 2010, 03:23 PM
Lean=more power.
Lean and rich are relative terms, and either can lead to less power. In the case of AP1's, they tend to run very rich, so leaning them out tends to lead to more power. However, AP2's are NOT rich from the factory, so you have to add fuel as you mod them in order to achieve gains.
Old Mar 18, 2010 | 04:23 PM
  #29
kaissi's Avatar
Thank you gernby,
it's relative... and when I say lean, that means too lean ..over stoich...
and that is dangerous on the long run..
probably AP1 2000-2003 are rich enough to get gains from minor mods ?! and not 2004.. EDM..cause that what happened with me..
And yes I notice spikes around 14.2 at vtec transition than stays around 13.8...13.5 until 8200-8300 and above, it starts riching to sometimes 11.9....so the richness if that what guys are talking about is barely 800 RPM range at limits... however the other 2300 RPM 6000-8300 .. the car becomes veryyyy lean if equipped with such mods...
I installed a header once, and the car reached 16 at vtec transition, yes 16...I saw the number, and immediately, I took it off.. and I took off the 70mm n1 exhaust too at the moment..
I just got the AEM EMS V2.. and plan to install back the mods again and tune but 63mm exhaust this time.. I say 70mm is too large for NA...
you might benefit at 8000-9000 RPM.. but you will definitely loose at the whole range below that
Robertttstyle
May 28, 2014 04:50 PM
tylek17
Feb 15, 2010 03:38 PM
kaissi
Dec 9, 2009 07:01 AM
THE_DIESEL
Feb 2, 2008 06:20 AM
rnye
Sep 15, 2007 09:22 AM
