Sponsored by: CARiD
Are these genuine?
Old Dec 1, 2008 | 05:04 PM
DDuds2k's Avatar
Default Are these genuine?
Original post-- https://www.s2ki.com/forums/index.php?showt...&#entry14827800
-- Responses to original topic would also be greatly appreciated.
Hi. I was told my master and slave cylinder are in need of replacement. I was wondering if anyone knew a good place to purchase them from since Honda likely charges an arm and a leg. Has anyone ever ordered from this place below? .
Master cyl
http://www.partsgeek.com/catalog/200..._cylinder.html
Slave Cyl
http://www.partsgeek.com/mmparts/sla...nda/s2000.html
Left motor mount parts:
Not sure what all is needed, or where to get it.
Old Dec 2, 2008 | 08:27 AM
snakeeater's Avatar
Try to look for signs of leakage at the master or slave cylinders or the cable between them. Leak will cause soft pedal and possibly incomplete clutch actuation. Flush and bleed the clutch line and refill with fresh fluid. You might fix the problem cheaply yourself or through a local mechanic that way. Odds of both master and slave cylinders actually being broke at the same time are pretty slim.
It's the dealer's labor rate that makes the quote high. Parts are probably less than half the total bill. That's normal. Try hartopguy website (he's a sponsor here) for new parts prices (a little cheaper than your dealer probably). Also, you can get rebuild kits for both cylinders for dirt cheap. Or try the classifieds here for used parts.
Dealer's service department has little incentive to spend much time diagnosing problem to save you money. Some often just replace parts until it works, and make money off the parts and labor, when a more thorough inspection might provide a simpler cheaper solution. Uninformed customers are their (and many mechanic's) wildest dream.
Old Dec 7, 2008 | 10:02 AM
zbrewha863's Avatar
The site says the parts are OEM
ktwenty
Nov 9, 2014 12:23 PM
roel03
Jan 29, 2013 07:13 AM
VIS2K
Jan 23, 2010 08:11 PM
G2k
Jan 25, 2009 06:34 PM
hokiemax
Nov 11, 2008 04:13 PM
