Throttle Body
Originally Posted by essi1553,Jul 29 2010, 12:28 AM
I dont see one compatible with an s2000...
Even if you don't want the throttle body, that site has the Omni TPS.
Originally Posted by xasrielx,Jul 29 2010, 12:05 AM
that is only on the s2ks with drive by wire right? cause if it has a throttle cable it doesnt need a tps does it?
Originally Posted by esmith51,Jul 28 2010, 11:20 PM
It started showing some symptoms of a bad TPS about a month ago. It would stumble at idle dropping from 1000 rpms to 200 or 300 rpms and finally shut off. This occurred more often on the first time it had been cranked in a day. I haven't done any further checking to see if it may be the ECU. I have checked to make sure it had a good connection. I appreciate the advice. I had been trying to look around and see what the best deal was. I figure I might as well get something that performs a little better if I am going to be spending about the same amount of money. I'll keep everyone posted on how it all pans out.
Interesting, I thought it was a sure fire sign.
http://www.buzzle.com/articles/symptoms-of...ion-sensor.html
The S2000's ECU uses MAP much more than TPS to determine fuel and timing. AFAIK, the TPS is just used to determine open / closed loop and to improve throttle response. The article above seems to be about all cars in general with unspecific designs.
^ yea that is what I was wondering. I just also thought TPS would be the suspect b/c there are several threads on here of people having the same problems (rough, low, high idle and stalling) once they install a new throttle body and don't adjust the TB properly.
Its a 2000 model with 110,000 on the odometer now. I am sure the MAP is the original which, were problematic on the early S. ^ I had read a few of the articles that were discussing the problems with TPS. The car would usually idle at 1000 rpms as long as it wasn't cold out. It then began to fluctuate between 700 and 1000 rpms occasionally dipping below that. I made sure the idle was adjusted and the throttle cable. It still did this occasionally. Later this summer it would drop from the 700 down to 200/300 rpms. A blip or two of the throttle and it would settle back at 1000 rpms. This gradually got worse. It typically occurred at the initial start up for the day. Later it would drop and stall out from idle while sitting at a traffic light. When I pulled the code and it said throttle position sensor, it came to no surprise. But, I plan on checking it more thoroughly when I get back home and pinpoint the cause. I left the car there to avoid any further problems (off at college and don't have tools here to repair if anything did go awry). I feel that it might be a combination of early MAP problem and a faulty TPS. I ordered the Science of Speed throttle body. So I'll have a new MAP and TPS. After I get this resolved, I am sending it with my friend who is an audi mechanic to adjust the valves and inspect the keepers and retainers.
