Sponsored by: CARiD
Tire pressure
Old Oct 5, 2016 | 02:58 PM
Xeon's Avatar
Default Tire pressure
Hi guys I have a ap1 with stock tires and rims (205 front 225 rear)
The recommended on the door is 32psi cold I believe
I have potenza re970as pole position tires with 65 percent tread left on them
What air pressure should I run cold? I live in Los Angeles California
I am running -1 front camber -2 rear camber [uk spec]
Old Oct 5, 2016 | 03:39 PM
Utah S2K's Avatar
32 front/34 rear
Utah
Old Oct 5, 2016 | 03:52 PM
S_DosMil's Avatar
Use the search function I'm sure a lot of the questions you have been asking have been covered.
Old Oct 5, 2016 | 11:16 PM
Xeon's Avatar
Originally Posted by Utah S2K
32 front/34 rear
Utah
What benefits happen with a higher rear pressure
Old Oct 8, 2016 | 04:02 PM
jst2878's Avatar
32 all around
Old Oct 8, 2016 | 06:14 PM
dsthez's Avatar
Why dont you play with some presure set al at 40 drive it drop by 2 psi drive and repeat. Btw get a new / accurate air gauge.
Old Oct 8, 2016 | 07:50 PM
Xeon's Avatar
I have a good air gauage
Old Oct 9, 2016 | 12:45 AM
tozerman's Avatar
Definitely 32 all round (cold)
For a track day then 29 all round, again cold.
This is what I have done for years. This gives me a very neutral handling car, I can even go to 30 on the front (cold) for a bit of safe understeer if I so choose. If you run 32/34 fr/rr then you will be promoting oversteer as long as you are aware
VelocityXvolumE
Apr 18, 2011 07:38 PM
stoopidchris23
Feb 22, 2011 06:28 AM
JTNY
May 12, 2009 08:12 PM
someone18
Feb 8, 2006 12:02 PM
