Tp Install question
I didn't use anti-seize when I installed mine. And I didn't torque them, just made sure they were tight, similar to what I did with my exhaust install. No leaks and no issues other than the CEL for the O2 sensor (waiting on Invidia to send me the fix).
Yeah I didn't torque or use anything on mine either, or my last 3 exhaust systems and havent had any problems. Just tighten it up good and it will be fine. If a bolt is giving me problems while removing it, just soak it with WD40 and let it sit for a while, then try and it usually will break loose easier.
Use PB Blaster then use your foot to kick the socket wrench if you really can't get it off.
Mine was so rusted on we had to take multiple kicks after giving up using our hands.
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
_________
