Sponsored by: CARiD
Trunk dampers
Old Aug 14, 2008 | 01:36 AM
DBXFX's Avatar
Default Trunk dampers
Anyone know if there is such a thing? i need them for a carbon trunk
thanks
Old Aug 14, 2008 | 02:22 PM
slightly2ned's Avatar
thanks
You can fab one out easily if you have a set of hood dampers. I would think you only need one, but it may still cause stress on the trunk while in the process of closing the trunk.
Plus you would need to make sure there is clearnce around the perimeter of the trunk to fit the damper so the trunk can actually close.
Try looking for dampers from other cars at junkyards, you might find a damper that is just right in size/pressure.
Old Aug 14, 2008 | 02:56 PM
leester01's Avatar
You can take the tension out of your current trunk spring bars yourself if your willing to do the work.
Remove your trunk lid,put two bricks or heavy item s on the trunk mounting rails so they are down in the trunk closed position
Put some fireproof foil up against the body and heat up the center portion of the spring bars with a propain torch while they have tension applied to them from the weight(be careful not to soften them up too much or the trunk wont open at all)
The springs will now have less tension in them but will have the paint burnt off so you can now remove them and put a new coat of black paint on
Old Aug 14, 2008 | 08:32 PM
DBXFX's Avatar
^^ cool, might have to give that a try... any way i can do it outside teh car.. i already have the spring out
Old Aug 25, 2017 | 02:18 PM
phiaceko's Avatar
Did you get a chance to try this out? Was thinking about doing some things to open up my trunk a bit.
Old Aug 25, 2017 | 03:44 PM
Manga_Spawn's Avatar
Site Moderator
Thread is 9ish years old?
sam i am
Aug 29, 2013 07:54 AM
djmike
May 20, 2008 08:05 PM
