Sponsored by: CARiD
VAFC2
Old Nov 11, 2009 | 01:29 AM
s2konroids's Avatar
Default VAFC2
Using a vafc2, has anyone monitored there AFR ('WOT') settings after a month/a few weeks on a dyno? - I'm not interested in partial throttle.
I went back after 2 week or so and the AFR was still the same, just wondering after a month or more than 2 weeks, has the AFR has gone back to stock AFR (before tune) ie the ECU has learned over it.
Reason being IIRC STFT effects the LTFT
Folk say it wont learn over WOT settings but like more input, technially wise.
Cheers
Old Nov 11, 2009 | 04:36 AM
Almostlude's Avatar
On VAFC2 when you are WOT that's when the tune comes into play and no your ECU won't "relearn" your WOT tune. Your AFR will vary somewhat depending on several conditions, including temp/humidity/etc. This is the main reason that people don't like the VAFC/VAFC2 is because you can only tune at WOT. Other engine management systems allow you to tune partial throttle as well as WOT. The partial throttle is where your ECU "learns/re-learns"
I am not claiming to be an expert by any sense of the imagination so perhaps others can chime in.
Old Nov 11, 2009 | 07:01 AM
s2k aok's Avatar
basic NA should only be tuning WOT for power, if you wanted more power than you should be pushing down on the pedal more.
i still have to get around to tuning mine for the PRM intake. it's nice that the WOT is a fixed schedule and doesn't get relearned 'cause the vafc is such a nice cheap tuning tool.
Old Nov 11, 2009 | 07:21 AM
Burt Reynolds's Avatar
Isn't the Hondata ECU upgrade tuned for WOT as well as POT? If there is more power or responsiveness to be had at POT why not take advantage of it just the same as WOT...
Old Nov 11, 2009 | 07:39 AM
s2konroids's Avatar
Thanks guys i posted this twice sorry (much better technical replies in this thread than the other), my logic for asking was from a technical POV and most threads just say it doesnt learn over WOT as its open loop.
It fine saying its not adjusted in open loop but this has input for the LTFT, partial throttle STFT effects LTFT, IIRC WOT looks at LTFT too you see?.
Old Nov 11, 2009 | 07:42 AM
s2konroids's Avatar
I got gains with the VAFC2 im happy just left partial throttle adjustments to 0.
liquid_helix136
185
Aug 6, 2010 11:52 AM
dan_uk
Nov 26, 2009 09:28 AM
s2konroids
Nov 23, 2009 07:38 PM
EK9MAX
Sep 27, 2006 08:07 PM
Pixsurguy
Jul 16, 2001 02:46 PM
