Sponsored by: CARiD
Valve Job?
Old Apr 8, 2010 | 06:43 PM
R.O.C.'s Avatar
Default Valve Job?
Hey guys! i currently own an 03 s2k with 93k miles on it. I have been having misfiring issues for the past couple months now. I have done a couple of things but nothing seems to fix the problem. i started having codes P0102(misfire Cyl.2) and p1399(random misfire). Now it started throwing me all the misfire codes. The car feels like it runs fine to me. I took it to a Honda dealer today and had a diagnostic test done. My compression on cyl 2 & 3 are way low.. he said basically they are out. They said it is highly likely i have bent valves, the only way to tell is to open the head. My mind is set on a valve job. I plan to go forced induction in a year or so. I want to just change my valves,retainers,springs, etc...As far as parts go, what do you guys recommend, and what parts should i change? I see a lot of people on here recommend Supertech valves. My goal is to push no more than 400whp. should i stick with OEM parts and get ap2 retainers and keepers? any info will help me greatly.
Thanks!
Old Apr 8, 2010 | 07:47 PM
Zoomie's Avatar
i would vote for AP2 OEM parts. The valvetrain components are much improved.
Old Apr 8, 2010 | 09:02 PM
playground_the's Avatar
before u set your mind to a valve job, pay a little extra to do a leak down test, leak down will tell you if it really is the valves that are leaking and which one is leaking, or its the cylinder that is leaking.
Old Apr 8, 2010 | 09:06 PM
R.O.C.'s Avatar
i just had a leakdown test done today at a Honda dealership. cylinders 2 & 3 are bad
Old Apr 8, 2010 | 09:10 PM
R.O.C.'s Avatar
Test results are 5%,95%,95%,4%...yea i know 2 &3 are gone.....if they are that bad can it really be bent valves?
Jessiel11
Sep 13, 2018 05:46 AM
justind
Jun 4, 2013 11:43 AM
s20001988
Sep 9, 2012 05:22 PM
R.O.C.
Apr 9, 2010 06:54 AM
Kondor999
Apr 17, 2007 07:29 PM
