Sponsored by: CARiD
Will This Work?
Old Oct 29, 2009 | 07:57 PM
mpetus's Avatar
Default Will This Work?
I have searched all day for an answer to this, but I'm not finding anything. Seen plenty of pics but no explanation to any problems incurred.
Car:'07 AP2. I am running Volk LE28n's 17x9/17x8 with the correct offsets (63mm/forgot the front....) 225-45 front and 255-40 rear. I just bought some used Tein S-Tech springs on Koni yellows. The springs are on the lower setting on the shocks which is supposedly 3/8" lower than stock. I have been trying to figure out if I need to move the perch up to the factory notch to prevent rubbing. I will not add more negative camber and prefer not to roll the fenders.
Oh- I am also using CR sway bars which should help prevent twisting over uneven pavement (driveways) but I know it won't completely eliminate pushing a tire deep into the wheel well.
Has anyone had any experience with this set-up or something similar?
Thanks in advance for any input.
Old Oct 29, 2009 | 08:08 PM
RL1924's Avatar
The offsets pretty high you should be fine. I run 18X9.5 +55 in the rear with no problems with a 255 rear
Old Oct 29, 2009 | 08:13 PM
mpetus's Avatar
Dropped? I'm looking at a minimum of 1.5" and right at 2" on the lower perch where the springs are now...
Old Oct 30, 2009 | 04:00 AM
s2kAtTracks's Avatar
You should be fine with those offsets and that drop. Im sure someone is running a setup close to what you want to run, might take a day or two for them to reply but someone should
Old Oct 30, 2009 | 09:11 AM
spook's Avatar
You'll be fine. I ran 255/40/17 and 235/40/17 on a similar suspension setup for a short period of time-- no problems.
blueprint
Nov 25, 2015 05:44 AM
VilleS2K
Nov 5, 2009 09:55 AM
whyspeed
Apr 30, 2008 06:29 PM
ernisill
Oct 23, 2007 04:06 AM
marknconnie
Feb 8, 2005 06:33 PM
