1320 heatshield 63mm test pipe?
this is a reposted thread. i wasn't sure if i posted it originally in the right section on the forum.
has anyone used the 1320 performance 63mm test pipe before? i was looking at getting the invidia one but i like how you can use the factory heat shield on this one for extra security in case i get checked by a cop.
I'm just wondering basic info. quality, flow, CEL.
Honda S2000 00-09 AP1 AP2 63mm Test Pipe & Heat shield TAB Cat Delete CEL FIX eBay
Well think of it this way, without the heat shield you're going to get a ticket. With the heat shield you just cut down the odds of getting one. I'll take cutting down the odds.
ROD
ROD
Seems like a stupid topic to post about. It definitely would be better with it. I just didn't read anything about it on the forum about it yet. The real question was quality of this test pipe. I also didn't know I need a 90 degree spacer for the CEL.
Have one myself. It's not a 90 degree, it's just a spacer that removes the Sensor from the exhaust stream. Passed emissions with it. Our emissions is a code read combined with a visual (mirror to look under the car), so having the heat shield ensures passing that part.
Considering this piece costs practically the same as a Berk or Invidia test pipe, it's a no-brainer. My cat rattled itself to pieces inside anyway so it was cheaper than replacing.
I'd buy it from Ballade Sports. A trusted source.
https://www.balladesports.com/produc...ield-test-pipe
