S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
1320 heatshield 63mm test pipe?
Old 04-27-2017, 02:24 PM
samson123's Avatar
Default 1320 heatshield 63mm test pipe?
this is a reposted thread. i wasn't sure if i posted it originally in the right section on the forum.
has anyone used the 1320 performance 63mm test pipe before? i was looking at getting the invidia one but i like how you can use the factory heat shield on this one for extra security in case i get checked by a cop.
I'm just wondering basic info. quality, flow, CEL.
Honda S2000 00-09 AP1 AP2 63mm Test Pipe & Heat shield TAB Cat Delete CEL FIX eBay
Old 04-27-2017, 02:38 PM
s2000ellier's Avatar
unless you are like street racing with neon lights glowing under you car while purging your NOS, no cop is going to look under you car.
i'm sure it will work fine
Old 04-27-2017, 04:51 PM
samson123's Avatar
lol thats what i was thinking. just kind of paranoid. the cops are really annoying in toronto.
Old 04-28-2017, 08:18 AM
ES2K's Avatar
If anyone looks, the 90 degree sensor adapter/CEL fix will tip off cops and smog check technicians.
Old 04-28-2017, 03:34 PM
samson123's Avatar
i was going to put the stock cat on when i do my emission test.
Old 04-30-2017, 08:26 AM
rrounds's Avatar
Well think of it this way, without the heat shield you're going to get a ticket. With the heat shield you just cut down the odds of getting one. I'll take cutting down the odds.
ROD
Old 04-30-2017, 08:45 AM
samson123's Avatar
Originally Posted by rrounds
Well think of it this way, without the heat shield you're going to get a tickit. With the heat shield you just cut down the odds of getting one. I'll take cutting down the odds.
ROD
Seems like a stupid topic to post about. It definitely would be better with it. I just didn't read anything about it on the forum about it yet. The real question was quality of this test pipe. I also didn't know I need a 90 degree spacer for the CEL.
Old 05-08-2017, 09:33 AM
ap1 George's Avatar
The difference is between getting a fat ticket for having a test pipe vs getting a ticket (if emissions tested in the street by checkpoint) for having a "broken cat".
Old 05-15-2017, 06:09 AM
duffman13's Avatar
Have one myself. It's not a 90 degree, it's just a spacer that removes the Sensor from the exhaust stream. Passed emissions with it. Our emissions is a code read combined with a visual (mirror to look under the car), so having the heat shield ensures passing that part.
Considering this piece costs practically the same as a Berk or Invidia test pipe, it's a no-brainer. My cat rattled itself to pieces inside anyway so it was cheaper than replacing.
Old 06-03-2017, 12:51 PM
davidc1's Avatar
I'd buy it from Ballade Sports. A trusted source.
https://www.balladesports.com/produc...ield-test-pipe
Quick Reply: 1320 heatshield 63mm test pipe?
