3" single power gain/loss question
Why go 3" when you can go 4"? You wussies.
But anyways, I think I read somewhere that too big an exhaust could lose power because of exhaust gas velocities or something.
Actually here, but I'm also sure I've read it somewhere else as well.
Well I'll be damned - my mistake. I've always heard that anything over 70mm on a mild N/A F20/F22 will definitely lose power. Seems those sources may have been wrong.
the only thing you will lose is your hearing if you dont get enough mufflers You will gain power in all area's of the power band. IIRC there was a shop that tested a few different diameters and they found open head produced the best gains (albeit redonkulously loud) so the less restriction after the header the better.
Originally Posted by fireball,Mar 19 2010, 07:00 PM
can anyone post a dyno chart , showing the benefit of goin 70mm to 76mm ?
Well, I'm buying one and will put a quieter muffler on there. Not sure when I'll get that done as I am too busy with work and have other projects for the car (suspension install). When I do I'll keep you posted, but I'm not sure I'll do a before and after dyno.
