Any objective tests on cooling plates?
Would that refective heat barrier reflect the heat back up to the hood? I have a CF hood and would be worried that by reflecting the heat back at the hood, that it would speed up the oxidation process...any feedback?
don't be so sure. Many turbo cars iwth top mount turbos (fwd cars) have issues with CF hoods due to the heat under hood. though I doubt it would be an issue with a non-turbo S, it's still possible, but not relating to oxidation but destroying the gel coat.
If it's a VIS hood, I'd be worried. I've seen/experienced nothing but issues with the coats on their hoods.
It is definently a VIS, lol...mine had oxidation real bad, so I went and had it sanded down and painted...no problems since, but I think by reflecting the heat back up to the hood, COULD cause a similar effect. What would be the best material for a cooling plate? CF or aluminum? Best brand?
aluminum dissipates heat better IMO than CF, but the difference is probably negligible between the two vs. steel.
I like the AUT plate and might pick one up myself when I get the K&N intake.
The AUT would be ideal for a snorkel setup...but what would be beneficial for a tube style cold air (i.e.: AEM V2)? Also, i did a search for putting reflective heat tape around the cold air intake to help improve temps, but came up empty. Has anyone possibly tried that as a method to lower intake temps?
There's an article in a recent import tuner about wrapping the intake piping with something, supposedly added 2hp average over a series of dyno tests. Seems to me that'd be hard to test.
