S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
ASP Header
Old Jan 29, 2014 | 06:21 AM
  #21
Gernby's Avatar
Former Sponsor
Originally Posted by VTEC2000
I saw the dyno chart on asp website. Is that with tune. If Honda factory header is way to go with all motor build Cause its so good. Why does spoon and mugen change it? Help here? I'm doing all motor build myself. Or am I missing something...
I haven't looked at their dyno plots, but I tested it myself. IIRC, it was the first prototype URGE made, and had it sent to me. He tried a few different prototypes from at least 2 fabricators, and the only one that showed gains was the "Unicorn".
Old Jan 29, 2014 | 06:26 AM
  #22
Gernby's Avatar
Former Sponsor
Forgot to answer your question about Mugen and Spoon ... it is possible to make a header that performs better in some areas of the rev range, but they will almost always perform worse in other areas. I believe Mugen and Spoon just wanted to produce a header that made some gains with the stock tune (or their ECU's). However, if you plan to eliminate the OEM cat, or if you're lucky enough to get ahold of one of my mid-pipes, you really need a header that has a very broad / smooth torque curve with VTEC set at ~3600 RPMs, like the OEM header.
Old Jan 29, 2014 | 11:54 AM
  #23
Nik2k's Avatar
i read a lot, and JS RACING HEADER give gains in all areas...
Old Jan 29, 2014 | 06:36 PM
  #24
juntsky's Avatar
If that's the case, why is there not an OEM replica that weighs less and why does everyone seem to think the hytech header gives gains all over (and plots show this)
Old Jan 30, 2014 | 05:40 AM
  #25
AngryTurtle's Avatar
Well that was easy. We can close this subforum now.
Old Jan 30, 2014 | 07:55 AM
  #26
Nik2k's Avatar
why ?????
Old Jan 30, 2014 | 10:56 AM
  #27
Fokker's Avatar
Originally Posted by Gigdy' timestamp='1391092828' post='22990543
[quote name='Nik2k' timestamp='1391028894' post='22989485']
why ?????
[/quote]
In the possible event you didn't catch on, that was sarcasm.
Startrek
Jan 25, 2016 05:13 PM
Mchester
May 7, 2012 07:21 PM
control_freak
Dec 12, 2010 09:08 AM
j66
Mar 14, 2007 03:46 PM
TCS2K
Sep 16, 2001 10:06 PM
