Engine whine(without accessory belt)
make sure its not 180degs out !!
rotate engine 2 or 3 times with a spanner on crank nut to check timed up correctly before any attempt too start engine.
Really screwed now, if i place the chain on the cam gear marks and spin it, the chain somehow skips teeth and ends up on a different position on the cam gear.
also the crank pulley, crank angle wheel and chain gear arr not aligned what a cluster bomb.
Just very confused about how to get the engine back into timing because there are so many moving parts. But i have found that i can just rotate the crank pulser plate with a small pick. Need to get the crank pulley, crank pulser plate, and drive chain sprocket all lined up so i can slide in the woodruff key again all while getting the cam gear and CYL#1 at TDC. All without opening up the timing cover
Be careful when turning the crank with the cams out of sync, big possibility of piston to valve contact.
You should probably try and inspect the pistons for contact marks before firing it up again.
Unless the timing chain length is an exact multiple of that gear circumference it isnt going to sync up each rev. I wouldnt base anything off that. Should be obvious if you spin it by hand and it jumps teeth.
I reinstalled and went over everything from the roller rockers and up. Restarted the engine and not only did it make the SAME metallic slurry sound but i also noticed it was spitting out water at the turbo v-band flange. Phunk me sideways! When taking the turbo manifold off i noticed small droplets in the exhaust ports on the head but didnt think much about it. So now i have the metallic slurry noise AND water droplets showing up on the exhaust from start up as you can see on the video:
After watching the video i figured it was a leaking vband clamp but ive double checked and thats not the actual engine slurry sound its something else. Just about running out of ideas
Does this look normal? Teeth on cam gear dont seem to be fully engaged. Camshafts properly aligned are still a few degrees off relative to crank pulley timing marks. And i have oil/water possibly leaking into exhaust ports. Im taking everything off and taking a closer look to diagnose
That video was too Blair Witch for me... Water out the exhaust, particularly after a cold start is normal as it is a byproduct of combustion and heating up cold parts.
