gears with 100 shot
gears with 100 shot
hey guys im still planning on doing a direct port 100 shot and maybe 125 on race gas and was wondering would i benifit from a 4.77 gears or would that hurt me in my ap1? i know all motor it would help me alot. just wondering what it would do with spray. thanks guys.
You would have to define "help". If you are going to have drag slicks, then the 4.77's with N20 would be awesome. However, if you are just on street tires, the 4.77's would totally suck big monkey balls.
For any car with a "good" system, you would have a switch that turns on the N2O system, then an ECU that turns the N2O on based on being at full throttle only and between a minimum and maximum RPM. The torque gain from N2O is inversely related to RPM, so the lower the RPM, the bigger the torque gain. IF you sprayed N2O at idle, you would blow the motor.
read my sig for nitrous info...and mssg juiceds2k he had 4.77's on his 100 shot and said he liked them...me I have my stock gearing with my 100 shot and couldn't imagine adding gears the tires would spin to much for sure...once you spray the 100 shot you won't be thinking of gears...and you won't need race gas for the 125 shot...i'm going next month for my bump up from 100 to 125 shot retune
