S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
HELLP INVADA TEST PIPE CHECK ENGINE LIGHT ON
Old Dec 31, 2012 | 06:33 AM
kandyred's Avatar
Default HELLP INVADA TEST PIPE CHECK ENGINE LIGHT ON
I PURCHASED A INVADA 70MM TEST PIPE WITH THE CHECK ENGINE LIGHT CANCLER ..I RESET THE CODE AND IT WENT OFF FOR A FEW HOURS, BUT AFTER DRIVING A FEW HOURS THE LIGHT CAME BACK ON AGAIN..DID ANYONE EVER HAVE THIS PROB? IS THEREA SOLOUTION TO THIS??
Old Dec 31, 2012 | 06:44 AM
Biohazard's Avatar
Don't yell, no need to use upper case. The cel fix on the invidia test pipe need an additonal angled defouler attached to it to keep the cel from comming up or you need flashpro if a 2006+ to just turn it off.
Here is a link to a good angled defouler that will work.
http://www.kseriesparts.com/cr/CLU1-CEL-ANG.html
Old Jan 2, 2013 | 05:38 AM
Reckon's Avatar
If you got the adapter from Invidia it might and might not work. Get a spark plug defouler and add it to the adapter to get some extra clearance. That should work - has worked on mine for quite some time now!
Old Jan 2, 2013 | 03:29 PM
s2cho's Avatar
yep only way is to get flashpro and manually turn it off with that. 06+are to sensitive and even with 2 stacked defoulers on 06+ wont work from what i read.
Old Jan 6, 2013 | 01:24 PM
bewareofthepoop's Avatar
http://www.kseriespa...U1-CEL-ANG.html
I have that and it works like a champ!
Old Jan 7, 2013 | 02:30 PM
Trackforged's Avatar
Former Sponsor
What year is your car OP?
Evan
Old Jan 8, 2013 | 09:11 AM
liras2k's Avatar
yup, i have a 01 S and the same tp. even with 2 spark plug defoulers, the CEL is still on .. need to try that angled CEL fix soon
MBHs2k
Mar 30, 2011 10:29 AM
teggytegteg
16
Mar 23, 2010 07:01 PM
trojanguy1
Nov 6, 2009 12:49 PM
boostinblue
Jan 4, 2009 09:29 AM
MADBADGER
Dec 1, 2007 10:19 AM
