INSTALLING ITBS
hey guys me and my brother have decided to put the itbs on the S although need some questions and help to ask. to put itbs on a s2k i have
1. injectors, o rings and clips
2.itbs and fuel rail.
3.aem ecu
will i need to upgrade anything else like a new gasket, fuel pump, fuel reg or maybe get new fuel lines rather then the stock ones? any help will be appreciated thanks guys
3.aem ecu
To my knowledge, a fuel pressure regulator would help and a thicker intake manifold gasket might help. If you get a insulated gasket, it might prove more beneficial due to less heat absorption. There are other possibilities some of which might be better than my suggestion.
Just my two cents.
-Hunter
Just my two cents.
-Hunter
3.aem ecu
3.aem ecu
Originally Posted by CarbonYellowJ's,Mar 26 2009, 03:55 PM
Ive seen people need a vacuum block so its possible to hook up more than one connection. I could be wrong.
pierceman
Oct 7, 2008 12:46 PM
