Lumpy idling cams?
Wouldnt bother with cams on an S2000 they are 'near enough' perfect on the stock setup, sure there is some power to be gained but not an awful lot.
Vtec killer cams will kill you, they named this because when vtec kicks in the massive torque increase snaps your neck and you die.
How much of those gains are contributed to the cams a lot less than the ECU not a great amount as i previously said, most of the gains are with the ECU not the cams.
Misinformation
End Rant.
Most of the gain is tuning lol not the cams. And while we're bringig up tid bits of info how bout the more then one grenaded motors curtesy of these bc cams.
Stock cams can support over 600whp.
Na rewards are limited unless ur willing to stroke the motor. And to do cams just for 4 banger chop is retarded.
Vtec killer cams will work fine. Just idle kinda crappy and get poor mpg.
You're obviously referring to boosted motors. So this statement has zero relevance in this section.
I'd only run VTEC killers after I promote my AP1 to "toy" status. The benefits are nice, but loosing the non-VTEC lobe, would be awful for a daily driver(especially for these little motors).
Zero relevance huh? So on a 600whp s2k they are hardly a bottle neck or inefficient but on a 200whp na application suddenly they are?
Originally Posted by H22toF20' timestamp='1320270500' post='21123349
[quote name='camuman' timestamp='1320269032' post='21123270']
[/quote]
A engine that sucks in air and one that has air being forced into it make power in completely different ways.
Originally Posted by camuman' timestamp='1320271694' post='21123415
[quote name='H22toF20' timestamp='1320270500' post='21123349']
[/quote]
[/quote]
Nm. Ur right. Do cams on stock bottom end na s2k an make 10whp if lucky. Because stock cams stink for 230whp na s2k.
Originally Posted by H22toF20' timestamp='1320272572' post='21123463
[quote name='camuman' timestamp='1320271694' post='21123415']
[/quote]
[/quote]
[/quote]
Reading your comments hurts my brain. Do some research before you spout off. You wouldn't make 600 hp boosted unless you were tuned thats a fact. Sure the stock cams can work in FI, nobody is disputing that. But for people who don't want to do FI 20hp is a big deal for only 700 bucks.
Click the link and read it, you may learn something
BC stage 2 cams
