Originally Posted by flanders
(Post 24552619)
I actually asked Brian at Karcept about this a few years ago, here is part of his response.
Yes just ad another fuel map table and then put some negative numbers around those super rich areas.
Great info! Thanks for that.
I'm not exactly sure how vtec would work though with a separate map, since its a on/off switch essentially, not a blended map with percentages that you can stack maps the same way. Would have to do some experimenting there.
You wont be able to do any changes to VTEC since that table is locked.
I dont know how much my stock ap1 from 02 made, but after password jdm intake, 70mm header, greddy tic and an engine tq damper, I made 207 whp on two different dynojet dynos.
made 224 after tune. I got the tune not only to get the most out of my mods, but also because I suspected the test pipe would cause it to run lean..and lo and behold... |
