NA performance rebuild
Banned
You can always add more parts and make more power, etc.. it comes down to what you want.
"standard" oem rebuilds are extremely expensive for these motors. They are all always too worn out to re-use the stock pistons.. you can just hone the block and knock new rings on the old pistons, but I only do that in situations where thats the only option due to budget or time restraints.
Because ITB's aren't going to get you 20 HP on a bone stock motor, not to mention after you rebuilt the motor to OEM specs you will need to buy the ITB's, injectors, vacuum blocks, fuel pressure regulators, fuel lines, assorted vacuum lines, assorted fittings, an EMS, a tune, and a handful of other things I'm forgetting. You would be into the motor for way more than the $5,000 budget.
Originally Posted by AE85' timestamp='1391883788' post='23005519
Thats a massive amount of engine work for 20HP! Why not rebuild the engine close to stock, and just get some ITB's?
Banned
A stock rebuild is just as expensive. 90% of s2000 blocks are too worn out to just re-ring. Oversize OEM pistons cost around $1000, machine work on the frm is expensive and not many can do it correctly.
Originally Posted by Feezy' timestamp='1391898423' post='23005763
[quote name='AE85' timestamp='1391883788' post='23005519']
[/quote]
I have ITBs, and I did a bone stock baseline dyno and an updated dyno after the ITBs. They were at the same dyno, pretty close to the same temperature, and only a few weeks apart. I added the ITBs, and AEM V2, and test pipe, and a tune and I saw about a 14hp gain. I'd kill for the 30-40hp increase that people mentioned, but I just didn't see it.
Banned
You can do a quick hone and knock new rings in it, but chances are it wont last as long as the original stuff did.
