naturally aspirated power?
#21
Itb 2250$ extra "so its a comparative build"
Balade sport k swap conversion kit 3,699.99$
Hondata k pro 1500$ (new rsx computer)
Tuning 500$
Total 16,348$
As you can see you are far from half the price here but it is not a bad swap and all
Also it uses 13.5 or 14.5:1 vs 12.5 for a urge build so it is a wilder build and can have issues on pump gas
Another advantage of the f20 f22 is that the fully ported head can flow more then a k series one in the end so its another + for the F series
So we are talking 2-3k difference down the line with the k series swap but they are more readily available and if you blow one up your not stuck buying cores since they include them in the price so i guess its more like a 3-4k difference in the end
#22
there are a ton of 2.4 liter motors with stock, head, stock intake, stock header and stock exhaust in the 260hp range.
There is no reason a 2.4 cant be reliable. We build k24's that make 300hp on pump gas all day long and last a long time.
A 2.4 will be more responsive, rev the same and last a long time. been there done that. The main roadblock for an s2000 is intake manifold and cam selection, both of which we are in the process of fixing.
Your now talking about a different engine i taught you where talking about a stroked f series engine ?
yes the k24 have better rod stroke ratio then a stroked f series so you are not having to deal with the downside of stroker engine my bad lol
#23
If I was to aim for 300 I think I would go the 2.4 liter route as well.
Idlew1ld just to piggy back on some of your numbers if anyone is really interested in doing this.
Flashpro used is $550
Tune in my area is $300
I believe you had these listed at $1500 and $500. For "my" situation seeing as I have an 06. I've already knocked $1200 off your numbers. I'm sure I can achieve the same results and spend a lot less IMO. For middle class owners like myself I think it's possible to get to 300 hp with 10k or less.
I think I can argue the build quality of both engines would be similar.
#24
Please feel free to start a post and show us how to make 300whp reliable setup for 10k all inclusive including core swap parts headers tuning and all the other parts needed
I even took the time to show you a break down of a k swap crate that vendors sell that supports 300whp (and comparable type build with itb) and your arguing with this also so on this this will be the last post i do in this thread as i have no time to loose here with keyboard racers peace
#25
Uwan
#26
Banned
here's 300hp-- prices rough cause its easy to add
pistons - shelf wiseco pistons $550
rods - inline pro f24 rods with upgraded bolts - 800
crank - oem honda k24 - 350
crank modifications - 100
bearings - acl race - 150
gasket set - 200
RLZ CNC Cylinder head includes valve job, resurface and reassmeble 1500
Supertech valve springs/retainers 350
cams (right now bc2 soon svm 212) 650
intake manifold modified inhouse with q45 tb 1000
assembly 1000
block work (darton dry sleeves) 750
Thats 7400 give or take a little b/c of rough pricing. It'll make 300. our k24 packages are about the same price, they make 300 to the tires all day on pump gas. I assume everyone
gasket set - 200
assembly 1000
#27
Uwan I am sorry if that came out like this but i took the time to show you 2 comparative and i think i provided comprehensive comparative builds to ensure that information was kept real here and you now wanted to argue this with how you could get used part and what not and i did over react on this
I think you have some good understanding in what goes into these engine and 300-330 whp on mild compression is a lot on these and it may be possible to get them cheaper but to think that you can cut 44% off that build is not something that should be pushed to hard on the forum because allot of guys rely on this place for information and this might give them the wrong idea of whats actually involved in doing so
So on this lets keep it reasonable and realest possible for others and on my part i will try and be more patient time
thanks!
thanks!
#28
gasket set - 200
assembly 1000
gasket set - 200
assembly 1000
Your missing the swap kit which is half the price of that engine ecu and tuning and itb to make it an apples vs apples comparison with the engine combination i posted up there @ 18k
#29
So you are 7,400.00$ the swap i used as an example was 8,399.00$ there is still the cost of the swap to take into consideration so it still does not end up being 10k
I don't think people need to pay $15k plus to get these levels of power. If you are paying to have it built for you, yes, it will cost a lot more because of labor costs. As good and highly developed that the Urge motor is, no doubt, there are many ways to skin a cat and their motor is one way. There are many ways to get to 300whp -all motor. If a person was patient and skilled enough, the build can be done for substantailly less.
As you said before, people rely on these forums for information. If you post that Urge can do it for 18k, then you need to post how much a skilled "layman" can do it for in their own garage or shop. This would give a range of cost and be more representative, i.e. it could cost 9k-18k to gain......blah blah blah.
#30
No look at post 20 he is talking about a k24
