Originally Posted by chris_barry
(Post 20730317)
Originally Posted by freezingcoffee' timestamp='1309303760' post='20729065
No I would not. The smoothness of the throttles, lightweight flange, and good support from jenvey is good enough for me. If I had another chance, I would of just bought the Toda units. Keep in mind, Toda units are bored 4age throttle bodies with their flange, but they provide everything to just bolt-on. Some of the early Toda ITB's did use the 4age throttles ( B16 and other engines) but the F20C set I have are their own units. |
Hi I'm planing to install ITB on my AP1 (LHD). The choices I consider are: Jenvey, Toda and custom made Kinsler. I will need a air box as well, I know that Todas box is not 100% bolt on on LHD. Riht now the Kinsler was my first choice, and custom made box.
I have also AEM v2 and I will let some good tuner do the mapping. Right now I found Interpro in UK who are recommending me the Jenvey because they know it, they have done tuning of S2000 with Jenveys before and I can get an air box for my LHD Ap1. I will use my car mostly for street driving and occasionally on the track. I have also purchased iVtec, this should improve mid range, while the ITB should improve the top RPM range and throttle response. If we do not consider prices, what choice should I make ? I can go to any location in Europe as long as I get best tuning... :) |
I would go with Interpro, they helped us with our car.
2.2 on Jenveys with omex and it gave 286hp on racefuel, 265 on v-power. We have a Reviere airbox, but don't use there shoddy spring clip nuts to hold the cover to the backplate, two of ours cracked from vibration, were ingested and destroyed the first engine. You'll need to cut the mounting holes in the backplate on a slope to clear the front of the bonnet, and remove the reinforcement on the underside of the bonnet too. Mike |
Originally Posted by conkers
(Post 21479603)
What do you want pictures of?
https://fbcdn-video-a.akamaihd.net/c...7e2fb76aeccb12 hope this video link works, it shows the angle of the backplate required to fit a Revierie airbox and be able to close the hood. Mike |
Need Help
Hi All,
Just purchased my first ever Honda, and I'm loving it so far, however after reading the forums and watching videos online and sure in the future I'm going to watch to make more power, however due to my budget I wont be able to follow a supercharger or turbocharger route. Therefore ITB's seem to be the best way of increasing the performance of the car. However, the kits I've seen on the internet look and seem great, but I'm worried that I will require custom fabrication of mounting brakets or various things, and even an aftermarket ECU... I have already fitted a Radium dual catch can set up due to the blowby issues, this system need to have a vent to atmosphere filter fitted to work with the ITB's as it wont have an intake pipe to vent into. In conclusion, does the OBX ITB kit contain everything I need to convert my car to ITB's or do I require a new ECU/tune, and various items such a a new throttle cable/mount, injectors, fuel pump, etc, etc? Thanks so much! Dom |
Aftermarket ecu and tuning is an absolute must, this is mandatory for all bigger performance increasing mods.
Toda has the only "kit" that is as close as plug and play that you will get unless someone else pieced together parts for Jenvey/OBX or others. I suggest you start with a read through this thread for more info https://www.s2ki.com/forums/s2000-na...hread-1168313/ |
Originally Posted by Dom Bounty
(Post 24527364)
Hi All,
Just purchased my first ever Honda, and I'm loving it so far, however after reading the forums and watching videos online and sure in the future I'm going to watch to make more power, however due to my budget I wont be able to follow a supercharger or turbocharger route. Therefore ITB's seem to be the best way of increasing the performance of the car. However, the kits I've seen on the internet look and seem great, but I'm worried that I will require custom fabrication of mounting brakets or various things, and even an aftermarket ECU... I have already fitted a Radium dual catch can set up due to the blowby issues, this system need to have a vent to atmosphere filter fitted to work with the ITB's as it wont have an intake pipe to vent into. In conclusion, does the OBX ITB kit contain everything I need to convert my car to ITB's or do I require a new ECU/tune, and various items such a a new throttle cable/mount, injectors, fuel pump, etc, etc? Thanks so much! Dom You'll also want to check out Flanders build thread: https://www.s2ki.com/forums/automoti...build-1148081/ He goes into great detail about what he needed to do to fit the Jenveys to his car. The OBX is a copy of the Jenveys so you will need to so the same plus some to get everything working. |
I have a plug and play Jenvey/Hayard ITB kit that used to be Feezy's. It will come complete to bolt on. I have a standalone ecu to include with it. There is a tune on it, but you will need to get it dialed in for your altitude. Message me if your interested.
Originally Posted by pastoli
(Post 24527503)
