Raising compression with a head gasket?
I've been thinking about doing the spoon head gasket to raise engine compression
Would this reduce the piston / valve clearance?
I'm revving the f20c to 9300+ with a stock head + AP2 intake retainers
What other ways are there of raising engine compression?
Yes, the valves are coming closer to the pistons. But the intake cams will be a bit retarded because the cam sprocket is in the head. This could help to increase the clearance again. Don't know how both effects add together.
Best way to raise C/R are new pistons with higher decks.
CamGears.
https://www.s2ki.com/forums/index.php?showt...post&p=14420601
Scroll down to the cam gear section.
Originally Posted by Fierc3,Dec 14 2010, 01:55 AM
CamGears.
Former Sponsor
Well for what its worth, i ran the Spoon gasket on my 2.2 Motors. i reved them to 9k. No issues with hitting pistons, jus snapping rods from the RPMs. Lesson learned :/
