S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
Result j's parts on my S2000
Old Jun 17, 2011 | 12:29 AM
S2000-R's Avatar
Default Result j's parts on my S2000
Hello NA friends,
recently i dynoed my S2000 and i’ve got a few questions about the result.
As first my setup for now is :
- J's Tsuchinoko intake
- J’s exaust manifold (heat wrapped by j’s)
- J’s testpipe
- J’s 70RS single exhaust
- J’s engine toque demper
The dyno run was made on a dastek dyno and the results where:
- Max. power wheels: 215.7bhp @8657rpm
- Max. power engine: 251.1bhp @8950rpm
- Max. torque 208.5Nm @7907rpm
My question: is the result as it should be? What can I do to get that little extra?
Thanks for helping me out.
Old Jun 17, 2011 | 02:08 AM
JmanS2k's Avatar
You need a 70mm test pipe. I don't think the J's is 70mm.
Old Jun 17, 2011 | 04:54 AM
S2000-R's Avatar
Will that be a big difference? the j's is 63mm i think.
Old Jun 17, 2011 | 05:14 AM
vactor's Avatar
got a stock dyno to compare? what ecu are you using?
Old Jun 17, 2011 | 06:52 AM
Gernby's Avatar
Former Sponsor
You need a matching diameter TP and a tune. You won't get much benefit from bolt ons with the stock tune.
Old Jun 17, 2011 | 09:30 AM
psychoazn's Avatar
You need a baseline dyno. Do you have one? For all we know, you might have spectacular gains, or no gains, but I would suspect without a tune, you've gained 10-15hp and running extremely lean.
Old Jun 17, 2011 | 10:27 AM
S2000-R's Avatar
The ecu is stil stock and i dont have a baseline dyno. When we did the dyno they said the A/F was good and they could not do much more about it (with a uni chip tune).
I'm living in Belgium (europe) and overhere it is hard to find a good tuner.
would a 70mm trotlebody and a 70mm test pipe make any difference?
Old Jun 17, 2011 | 12:00 PM
Biff_Malibu's Avatar
You need a tune to truly extract the value of your modifications... I'm not sure what year your car is but go either K-PRO or AME EMS...
I don't think having a bigger test pipe will make a difference as I'm assuming the J's header collector is probably 63mm as well.
Old Jun 17, 2011 | 08:51 PM
Gernby's Avatar
Former Sponsor
The only thing you could do to improve your situation without a tine is to start putting the stock parts back on.
Old Jun 17, 2011 | 08:52 PM
Gernby's Avatar
Former Sponsor
... A tuning solution really needs to be the first mod...
