skunk2 ultra I/M with Pro-Jay 90mm TB
Building a 2.4 liter stroker motor. I have the bottom of engine built, the head on the my current F20 has BC valve springs and stage 2 cams which I will be reusing, and a 70mm ballade sports throttle body with port matched I/M. Does anyone think the Skunk2 manifold and this throttle body (http://pro-jay.store/shop?olsFocus=f...hrottle-bodies) combo will make power? is 90mm to big should I go with the 80mm, save my money and stick with my current setup?
I paired my 2.4L stroker short block with a K-series skunk2 ultra race and 80mm K-tuned TB.
See: https://www.s2ki.com/forums/s2000-na.../#post24192807
Definitely saw serious improvement over the stock AP1 IM that I port-matched to a skunk2 74mm TB. But I also have an upgraded exhaust (URGE stroker exhaust header, URGE midpipe/"gernpipe" and dual T1R exhaust).
The stage2 cams should get you over 300HP if you enable the 2.4L to breath properly (3.5" intake with quality IM, or ITBs, and exhaust). You don't need 90mm TB, 80mm would suffice (more responsive throttle the smaller you keep it)... Jeff Evans said that my TB upgrade from 74mm to 80mm didn't have any impact and only would help if I upgraded my cams.
If you want to make some serious NA power go with 4piston CNC head, 4piston custom cams and 4piston ITBs. If you want an idea of power check out 06estukay's build thread on here
BTW, not aware of anyone having actually tested the skunk2 F-series ultra race IM yet. There is a guy on youtube (pretty sure he is on s2ki too) who is sloooooowly building toward skunk2 F-series ultra race with K-tuned TB with cams. Like watching grass grow as he shows how to wire the map sensor, IACV etc. His name is Chase Diaz. He does a great job detailing what he is doing and stuff but I just cannot relate to taking months to get the car on the road. I installed my K-series ultra race, new radium fuel rail and FPR, spliced custom wiring (from K-series to F-series harness), ktuned TB, etc in a single sleepless and intense 48 hours one weekend. Anyway, just looked now and he posted part 13 of his youtube build series (he is working on a custom welded intake.. I just used silicone couplers).
Definitely saw serious improvement over the stock AP1 IM that I port-matched to a skunk2 74mm TB. But I also have a custom exhaust (URGE stroker exhaust header, URGE midpipe/"gernpipe" and dual T1R exhaust).
do ITB’s. The thing that keeping me from doing ItB’s Is getting though NJ emissions inspection. Right now even with my cams and tune. I just swap out my EMS for the factory ECU. Then drive it as slowly as possible and just enough to get the readiness monitors to set. Go get tested then swap back. If I do ITB’s I’m gosure no to have to swap the entire manifold over every 2 years. That just seems like a hassle.
This is tempting as my original goal was to
