Stock Spark Plugs Dyeing..
I got a GPW 2004 S2000. Ive it in the shop for the past few weeks, my good mechanical friend is helping me with the install. Right now i got an aftermarket header, angled single exhaust and injen intake. I got a text this morning from my mechanic friend that he feels like the spark plugs seem like they are starting to crap out. Its only got 45,000 miles on it. I trust the guys word, but i don't plan on replacing them immediately because I've had the car for a little over a month and have already almost put in $1,500 in it.
Im going N/A and was wondering if anyone can recommend a set of spark plugs that would give me the greatest benefit.
These are all pulled from the JDM S2000 spec sheets.
Platinum Pregapped 1.1 | PFR7G-11S (OEM Honda Recommended)
Iridium Pregapped 1.1 | BKR7EIX-11 (NGK Upgrade Recommended)
Banned
I use bkr8eix, gapped to about 0.030"
they will last a long time and work very well. When it got hot i was getting some detonation with the 7 heat range plugs.
they are only about 8 bux a pop at advance auto. I'd never leave plugs in my car for 40k miles.. they are cheaper than an oil change.
Banned
i found my car to run a little smoother with the plugs gapped down.
the ngk r's typically are non resistor plugs, which you do NOT want to use, they can cause all sorts of issues.
ngk iridiums are the way to go, they work much better than the cheaper copper plugs.
Banned
spec is 0.044 if i remember right. most of the time the iridiums come gapped at 0.030.
I run my car much leaner under cruise and light accel than the stock ecu does, that will stress any ignition system. I was also experimenting with running the car on e85, i was going back and forth between e85 and gas. That very well could have had something to do with it.
when you gap down the plugs it has the effect of advancing the timing, not retarding the timing.
NGK r's are non resistor most of the time (it depends on the exact part number)
Non resistor plugs will mess with electronic fuel injection systems, they can cause all sorts of EM interference.
