Testpipe size for NA tuning
So, I'm getting my car retuned with AEM EMS, 68mm TB, Megan racing header and possibly Skunk2 cams, valve springs and retainers. I have a Berk TP at the moment, which I believe is 63mm. Would I se any gains or advantage in getting a 70mm testpipe for an NA tune? Or will that not make a noticeable difference?
You bought cams, TB, springs, retainers, and a header before you bought an intake or exhaust? Interesting.
Either way, if you're keeping your exhaust stock then don't go with a larger testpipe. The test pipe / HFC rule of thumb is that it should in terms of diameter, greater than or equal to your header collector, and equal to or less than the piping diameter of your exhaust. Otherwise you'll create a bubble in the flow and create a lot of pressure.
yea, don't even worry about the test pipe.. why a 68mm tb? run a 72 and reweld the pinch and port match, always makes great gains.
are you running a stock exhaust... kinda a waste if you have engine flow work
if you're running a stock exhaust then just keep what you have. if down the road you switch to a 70mm catback then you might as well get a 70mm tp or hfc and then retune it.
I have an Injen "CAI" and HKS exhaust as well, but I'm not sure if I will use the intake or not. So the conclusion here is that it should be somewhere between the collector size and exhaust size if they are different...
Originally Posted by Dingodogspeed,Sep 29 2010, 08:11 PM
Wait, I have a question,,, your test pipe should be bigger then your header collector but smaller then you exhaust pipeing?
Seems that 3" is the rave right now.
