WHICH THORTLE FOR NA?
hi guys! i wanted to maximize the power in my ap1 with an jdm f20c engine. im planin on adding a throtle body but before i do it i would like to ask which throtle will be the best to use for my set up. i have a greddy EMU,j's racing header, asm exhaust, j,s racing tsuchinoko intake, testpipe etc i also have okada coils on the way. . im chossing between skunk2, spoon and j's racing. and wahat size would be the best?? thanks guys!!!
OEM until you go FI. Spend your money elsewhere.
oh ok but smoe say i can gain up to 5whp with the throtle i want to maximize the power of the car naturally aspirated and only on bolt ons. i want to see on howmuch power the car can make on allmotor with only bolt ons and no internal mods. thanks!!
you won't make 5hp with any tb unless you have the supporting mods.
TB's are more for throttle response than gaining HP. |
He has an EMU so he can tune!
A TB will give you a little power (around 5 whp) with a tune. I would get the J's with the 64mm size on the backside. That will match up perfectly with the stock plenum. The OEM TB is not port matched to the plenum, this alone probably costs you a couple HP. |
aren't you out in the phillipines or somewhere?
i would not buy any throttle body and sell the okada coils....then go get yourself the cooling mods ( lower thermostat and fan switch, radiator cap....you can get the hondata img also ). those will be much more beneficial than any throttle body or coil pack. you don't make any additional power, but you pick up a lot of lost power from heaksoak. and out there with the humidity and heat, i think this is a good decision. you can also run your em-u on more slightly more aggressive settings to get a little more power out of it. |
A TB will give you a little power (around 5 whp) with a tune. I would get the J's with the 64mm size on the backside. That will match up perfectly with the stock plenum. The OEM TB is not port matched to the plenum, this alone probably costs you a couple HP. J's |
a TB might make 5whp if you have an EMS... :thumbup:
Originally Posted by Js S2k,Nov 16 2008, 12:25 PM
I don't know how bad shipping costs will be, but there is a company call Proflow here in the States that can bore an oem tb. I'm looking into getting a 70-64 tapered one. They're only $195 + your oem as a core.
J's paying $500+ doesn't seem worth it to me though :) |
i would not buy any throttle body and sell the okada coils....then go get yourself the cooling mods ( lower thermostat and fan switch, radiator cap....you can get the hondata img also ). those will be much more beneficial than any throttle body or coil pack. you don't make any additional power, but you pick up a lot of lost power from heaksoak. and out there with the humidity and heat, i think this is a good decision. you can also run your em-u on more slightly more aggressive settings to get a little more power out of it. im also planin on porting the intake manifold . matched ported with the size of throtle that ill be getting. so is 68 or 70mm ok ??? i want to maximize the NA engine with all the available proven bolt on parts first before touching the internals of the engine. yup i have an EMU and il be having it dynojet tuned. |
