Valve clearence question
I have a BC stage 3 exhaust cam on the f24c...I checked the tolerances are VERY tight, (more then .21). The head has stock valves/springs, Intake cam is stock..
What tolerance should it be set at? Factory OEM settings (assuming not), or call BC for further info?
Any help guys?
Any help guys?
I don't see any reason why your choice in cams would change the valve lash requirements. If you are using the stock valves, seats, and rockers, then I'd stick with OEM spec minus 0.001" for intake (.007") and exhaust (.009").
ya when i bought my bc stage 2 cams they cam with a paper telling all the specs .And bc dose have there own specs ,if you call them they will tell you everything you need to know.
Banned
Why would a cam profile have anything to do with valve lash? Valve lash is the slack between the cam and valve when the valve is cold and fully closed (not touching the cam). As the valve heats up, the metal expands, and the gap closes. The cam profile has to do with the valve being open, not closed.
Banned
thats not what valve lash is for at all
if it closes completely the valve will never shut, if its too loose the valve train will be shocked when the cam lobe finally catches up to the rocker flopping around.
The end of the cam profile lowers the valve onto the seat gently. If you have too much valve lash the valve is dropped onto the seat abruptly and over time can cause the head to break off the valve, or the seat to get pounded.
Similarly, the initial movement of the valve opening is gentle to avoid shock loads as the lash is taken up, if your valve clearance is too large the cam takes up the lash on a more aggressive ramp and can damage the rockers and other parts of the valve train.
BC gave me this:
Intake-.010'
Exhaust-.008'
Not an expert by anymeans, but in my opinion from what i see, the cam has everything to do with the valve lash.. Factory specs calls for
Intake (.021-.025)
Exhaust (.025-.028)
Im not a genius, but when BC tells me the valve lash is to be set at .008, i find it hard to believe the cams dont have anything to do with the valve lash. Just look at the numbers. Now imagine if i set my valve lash to .025 on the exhaust side..Probably would get 3 seconds of the car running.
When i pulled my motor apart, certain valves were dirtier then other, cylinder one was completely nasty. When i started the valve lash i took note to check the the lash on those certain valves, and the leaky valves were the ones with the valve lash off the most. Theres a reason BC sent them a spec sheet....
Intake-.010'
Exhaust-.008'
Intake (.021-.025)
Exhaust (.025-.028)
