VHT Flameproof Primer on test pipe
Hey guys! not sure if this is in the right forum or not so I apologize if this is in the wrong spot. I was wondering if spraying my new test pipe with VHT Flameproof primer (temps from 1300-2000 F) would help with corrosion and possibly heat absorption. I know the best thing for me to do would be to add a heat shield to the TP but I was just curious since I had 3/4 of a can of VHT laying around. This would be just the primer but I do have the brake caliper paint from VHT (temps up to 900 F) laying around so I may spray some on too. Any ideas if it I'll do anything? Thanks in advance!
Decided to take the plunge and spray the test pipe in vht. I took some 80 grit and 320 grit sand paper to it and sprayed some simple green to remove any contaminates. After it dried I applied the vht and now I'm waiting for it to finish curing in the oven.
Update:
I decided to wrap the test pipe in DEI heat wrap. Not sure if it will help much but I'll report later (with pictures hopefully) on my experience after I finally get around to installing the tp on my car
