275 Square Setup on AP1?
Old Apr 2, 2012 | 05:26 AM
jaundice's Avatar
Default 275 Square Setup on AP1?
Hey guys,
I have a question. I have been running a 255 square setup with RS-3's for awhile now, but want to step up to A6's or V710's. I don't see that they make a 255/40/17 version in either of those? Is there a good autocross R compound in 255 or do all of the others take too long to heat up?
I am running TR Motorsports wheels 17x9 +62 currently with my 255's. I have rolled and pulled the front fenders and have rolled the rear fenders. I have no rubbing with this setup. Can I put the 275 A6's on these rims? Will I rub? I am more worried about the inside rubbing than the outside rubbing.
Any help would be appreciated. I am running BSP at SCCA and getting killed by the competition all wearing R rubber.
Old Apr 2, 2012 | 06:02 AM
MattP's Avatar
Jason Uyeda was running Hoosiers, "285/30-18 front, 295/30-18 rear, on 11" wheels" on his BSP S2000 without cutting the fenders.
Mentioned in this thread:
http://www.sccaforums.com/forums/for...86/scope/posts
Old Apr 2, 2012 | 06:37 AM
ummpwr's Avatar
It should fit fine with the tr offset. I was running the tr wheels with 275 nt01 all around and only had to modify the front fenders. I'm now running 949 wheels with 315rear 275 front on nt01.. Had to roll the rear hard but no cutting fenders.
Eric
Old Apr 2, 2012 | 09:47 AM
daverx7's Avatar
I can see myself going to SP from STR at some point. IMO, STR is a great way to work your way to SP. Good luck!!
-Dave
Old Apr 2, 2012 | 11:46 AM
thielepr's Avatar
Eric
pic please!!
Old Apr 2, 2012 | 01:58 PM
iLuveketchup's Avatar
The tires will rub the inside wheel well
Old Apr 2, 2012 | 02:08 PM
jaundice's Avatar
On the front or back or both? Is there a better offset wheel to use? I don't really want to go down to the 245 size if I can help it.
Thanks
Old Apr 2, 2012 | 02:22 PM
Thanks
The front wheel well. Do you have extended wheel studs? I think a 10mm spacer should help. Not sure if your fenders allow it.
Old Apr 2, 2012 | 02:40 PM
ummpwr's Avatar
949 wheels 315R 275F
tr motorsport front with 275s and a slight roll
http://sphotos.xx.fbcdn.net/hphotos-...33253153_n.jpg
315 Rear on 949 275 Front on tr
http://a4.sphotos.ak.fbcdn.net/hphot...12759271_n.jpg
Here is my thread on the tire fitment
https://www.s2ki.com/s2000/topic/931...#entry21451562
#ir
Oct 23, 2015 09:17 PM
20civic07
Oct 9, 2015 04:43 PM
sw20trd
Dec 25, 2011 09:47 PM
bumblebeeS2K
Apr 6, 2008 11:43 AM
General Kratos
Apr 16, 2007 10:49 AM
