3mm spacer safe with stock studs ?
Old Oct 2, 2023 | 01:28 PM
S2000_916's Avatar
Default 3mm spacer safe with stock studs ?
Just upgraded to bbk with tsw interlagos , would it be safe to run 3mm spacer with stock studs ?
Old Oct 2, 2023 | 05:37 PM
Bullwings's Avatar
Yes, but I'd also verify to make sure that the aftermarket rotor hat didn't also add some additional effective thickness.
I know that the Stoptech ST40 rotor hat is like the equivalent of adding a 2-3mm spacer. I know for sure since I rolled fenders prior to getting the bbk and had no issues rubbing, and after the BBK definitely had rubbing issues in areas where it wasn't a problem before. Adding a 3mm spacer on top of that would be like effectively adding a 5-6mm spacer to the OEM config.
Old Oct 2, 2023 | 06:13 PM
S2000_916's Avatar
Interesting , never thought of that
Old Oct 3, 2023 | 07:28 AM
Bri's Avatar
Bri
Dang. Didn't know the ST40s added an effective spacer. I just picked up some ST40s.
Old Oct 3, 2023 | 12:59 PM
Nate Tempest's Avatar
Note that if you do need to make a change and don't want to upgrade the studs (which is a big job on the S2000 because you need to pull the hubs, which means replacing the bearings...) you can buy a few mm by using extended thread lug nuts, like these for example:
Amazon Amazon
They basically reach into the lug nut hole to grab more threads. However, the TSW wheels have fairly small holes; I needed to bore mine out very slightly for ET lug nuts to fit. Was still much cheaper than replacing the studs though, although eventually I did that anyway.
Old Oct 6, 2023 | 09:49 AM
EffWun's Avatar
did not know that, Whoa! so my x10 +50 is effectively a 45-44 with 3mm spacers needed to clear the ST40 calipers. Was wondering why they were sticking out so damn far @ front even with -3.5...
Old Oct 15, 2023 | 05:58 AM
SlowTeg's Avatar
I can't remember what spacer size I'm running, it's either 2 or 3mm. I'm running a stoptech kit on stock studs and haven't had an issue. Not saying it's safe (more threads is better) but I think I've done ~8 track days or so with 255 rs4's with this setup.
Tegiwa Imports
UK & Ireland Traders Forum
Jan 15, 2013 11:13 PM
dc5type_S
Jul 12, 2010 03:21 AM
keemaca
May 19, 2010 09:11 AM
ToEnvy
May 13, 2008 04:29 PM
DJ Qube
May 23, 2007 09:23 AM
