ABS failure only on track
Originally Posted by mxt_77,May 25 2009, 06:08 AM
Do you use different wheels/tires on the street vs. track? If so, are the tires different sizes? Maybe the difference in wheel/tire speeds (caused by different tire sizes) are confusing the ABS computer.
probably sounds like the sensor fault/damage might be wat i need to fix.
Originally Posted by CKit,May 25 2009, 09:59 PM
The ABS computer is quite good. It doesn't mind different front and rear diameter tires very much. I'd be surprised if this was the issue, but I can't say for sure.
Originally Posted by mxt_77,May 26 2009, 05:31 AM
Understood... I was just trying to think of something that would cause this issue to be seen on the track, but not on the street.
Originally Posted by CKit,May 26 2009, 06:42 AM
Maybe if the signal from a dirty / damaged ABS sensor is weak and then the geometry change from static high cornering loads moves one of the rear ABS sensors a little farther away from the reluctor ring?
Originally Posted by Mrsideways,May 26 2009, 08:01 AM
What year? We had ours in the 2006 fail a year or so ago. Turned out to be the control unit. Now it activates to easily.
Originally Posted by ZDan,May 28 2009, 09:45 AM
FWIW, my car behaves fine under braking with no ABS
If you don't mind having to modulate manually to prevent lockup...
