Aem ecu with abs
Hi all, my s2000 has a aem ecu and the abs has been removed. I’m trying to refit it, does anyone know if the ap2 abs is standalone and can run without the original ecu? I’ve brought a pump but can’t connect with the eobd port
Now I'm curious. Has anyone been able to set up the OEM AP2v2 ABS system to work with a standalone? I'm nowhere near there yet but if an engine let go on me, I'd be tempted to k-swap. This would be another hurdle if it ever came to it for me.
Anyone know if an accord and/or TSX has a similar ABS setup? There's a company that now makes a harness to run a K on a TSX/Accord ECU but there are really no details about it.
Also, this issue applies to the EPS. EPS is looking for an RPM signal to energize it. Since it’s such a large draw, I think Honda wanted to isolate it till the car was started. You should be able to get the EPS to work, but it won’t be variable assist, due to the loss of OEM tach signal
If I was K swapping, I’d ask ASM Motorsports what they could get to work. They seem to be the experts
EDIT: some years back, Honda in California did a J swap into an AP2V2. My understanding is, they got everything to work thru the regular ECU. I’m guessing that’s because they had the engineering knowledge of how to get the sensor codes to work and run the J, along with the ABS, EPS, etc The car was unfortunately destroyed, because it was a demonstration project (it’s what the s2000 could have evolved to). I’ve never been able to find anyone with inside knowledge, so I could find out what kinda scale all the sensors are based on
