Alignment advice please for HPDE setup
Old Feb 23, 2011 | 04:01 PM
Ajjra's Avatar
Default Alignment advice please for HPDE setup
Been searching and coming up empty. I'm moving to R-Compounds this Spring and need alignment advice for my 2002 AP1 with AP2 sized rims. Should I go with AP1 alignment specs, as my car's suspension setup is stock or does the rim size matter?
Thanks is advance.
Old Feb 23, 2011 | 05:06 PM
psychoazn's Avatar
I would go with at least -3 camber all around if you're driving the car at a decent level of proficiency, and the r-comps will only be seeing track use.
You may discover you need more or less. The only way to truely determine that is with a pyrometer.
If you're on stock suspension at stock height, you'll need camber joints.
Old Feb 23, 2011 | 05:19 PM
Richard EVO's Avatar
I would go to Darrin at West End Alignment and agree with whatever he wants to do.
Old Feb 23, 2011 | 05:22 PM
ZDan's Avatar
If your suspension setup is stock, you're going to want to run maximum camber front and rear, which will probably put you at something like -1.25 front, -2.25 rear (plus or minus). Yeah, it'd be great to have 3 all around, but you don't *need* camber joints. I'm precluded from using them by showroom stock time trial rules, but honestly I wouldn't bother anyway unless a few tenths really really mattered.
Front toe zero or a smidge (maybe 0.1deg total) toe out.
Rear toe 0.2-0.3 degrees total (too much rear toe => wonky nonlinear handling AND greatly accelerated tire wear).
Personally, I don't worry too much about caster and maximize camber first. If you maximize caster you may be limiting camber.
My .02...
Old Feb 23, 2011 | 09:14 PM
caffeinefr3e's Avatar
Dan, you're a bit off on the stock ranges for camber. I hit 2.2 degrees in the front and it can do at least 2.7 degrees in the rear, completely stock.
Parth
Feb 15, 2016 11:53 AM
93silvergt
May 27, 2015 02:25 PM
Boostedtaco
Sep 8, 2010 07:58 AM
bakalag
Sep 30, 2009 08:22 AM
jack1122
Sep 10, 2005 09:34 AM
