alignment question
Old Sep 26, 2006 | 08:43 PM
PAYELS2K's Avatar
Default alignment question
is 4 degrees total tow in rear ok for track use and limited street use?
Old Sep 27, 2006 | 03:50 PM
teamking's Avatar
You'll be smokin' fast!
Old Sep 27, 2006 | 03:56 PM
mikegarrison's Avatar
Is four degrees toe even possible? Scary.
Old Sep 28, 2006 | 09:04 AM
teamking's Avatar
Of course it is. Try a search on xviper, alignment, and sledge-hammer.
Old Sep 29, 2006 | 05:27 AM
RACER's Avatar
Old Sep 29, 2006 | 06:18 AM
RACER's Avatar
Total toe is length that is dictated by overall tire diameter and degree of angle which will always be the same regardless of overall tire diameter. Therefore, an inquiry about total toe in degree's is an invalid question.
If you say, had two degree's of angle per wheel with an overall tire diameter of about 25, you would have approximately 1.5 inches of total toe
Old Sep 29, 2006 | 08:37 AM
WTF? Toe angle is not "always the same". Not on this car, anyways. But the correct toe is measured in fractions of a degree, not in multiple degrees.
Old Sep 29, 2006 | 12:59 PM
RACER's Avatar
Degree is a measurment of angle, where as inch is a measurment of length. The length changes depending upon the overall diameter of the wheel.
The overall diameter of the wheel has absolutely no effect on the angle of the wheel. The angle remains the same.
Old Sep 29, 2006 | 02:23 PM
blackey's Avatar
Did he mean camber?
Old Sep 29, 2006 | 02:57 PM
l8brakr's Avatar
^I doubt he meant camber because that wouldn't be referred to as a "total" number like he asked.
On a 25" wheel & tire package 2 degrees of toe would be .436" or 7/16" so total toe would be approx 7/8 of an inch. Certainly not ideal for performance or tire wear. Whether it's possible is irrelevant because you wouldn't ever want it.
WVCR-V
Jun 10, 2017 02:44 AM
mickey finn
May 10, 2008 09:36 AM
smurf2k
May 21, 2007 01:54 PM
Meyer
Nov 4, 2002 04:46 PM
Dorian Gray
Apr 22, 2001 05:47 PM
